kawasaki Z750R 33vdwmr
kawasaki Z750R
+8
Kovach
sagrado
Green Hornet
♏㋡ℕ㋡
daniel1973
12 participantes
kawasaki Z750R Empty kawasaki Z750R
Mensaje por daniel1973 Lun Ene 10 2011, 15:05
Kawasaki ensamblara en India en la fábrica Bajaj su nueva Z750R para ofrecerla en el mercado hindú.
kawasaki Z750R
Engine
Fuel system Fuel injection: ø32 mm x 4 (Keihin) with oval sub-throttles
Ignition Digital
Starting Electric
Lubrication Forced lubrication, wet sump
Engine type Liquid-cooled, 4-stroke In-Line Four
Displacement 748 cm³
Bore x stroke 68.4 x 50.9 mm
Compression ratio 11.3:1
Valve/Induction system DOHC, 16 valves
Transmission
Clutch Wet multi-disc, manual
Primary reduction ratio 1.714 (84/49)
Gear ratios: 1st 2.571 (36/14)
Gear ratios: 2nd 1.941 (33/17)
Gear ratios: 3rd 1.556 (28/18)
Gear ratios: 4th 1.333 (28/21)
Gear ratios: 5th 1.200 (24/20)
Gear ratios: 6th 1.095 (23/21)
Final reduction ratio 2.867 (43/15)
Transmission 6-speed, return
Final Drive Sealed chain
Frame
Frame type Tubular backbone (with engine sub-frame) ,high-tensile steel
Rake/Trail 24.5° / 103 mm
Wheel travel, front 120 mm
Wheel travel, rear 134 mm
Tyre, front 120/70ZR17M/C (58W)
Tyre, rear 180/55ZR17M/C (73W)
Steering angle, left / right 31° / 31°
Suspension
Suspension, front 41 mm inverted fork with rebound
damping and spring preload adjustability
Suspension, rear Bottom-Link Uni-Trak, gas-charged shock with piggyback reservoir
Rebound damping: Stepless
Spring preload: Stepless
Brakes
Brakes, front Dual semi-floating 300 mm petal discs
Caliper: Dual radial-mount, opposed 4-piston
Brakes, rear Single 250 mm petal disc
Caliper: Single-piston
Dimensions
Dimensions (L x W x H) 2,085 mm x 795 mm x 1,070 mm
Ground Clearance 165 mm
Wheelbase 1,440 mm
Seat height 825 mm
Fuel capacity 18.5 litres
Curb Mass 224 kg / 227 kg (ABS)
Performance
Maximum power 77.7 kW (106 PS) / 10,500 rpm
Maximum torque 78.0 N•m {8.0 kgƒ• m} / 8,300 rpm
daniel1973
daniel1973
Cantidad de envíos : 1309
kawasaki Z750R Empty Re: kawasaki Z750R
Mensaje por juancho_mdq Lun Ene 10 2011, 15:27
una belleza !!!! mf_lust worthy
Cantidad de envíos : 3759
Mensaje por Mat*. Lun Ene 10 2011, 15:33
Lo lindda.... Lo linda q esta esa moto. Es realmente hermosa...se q no son lo mas funcionable...pero como me gustan las Naked!
Cantidad de envíos : 7400
Mensaje por ♏㋡ℕ㋡ Lun Ene 10 2011, 15:47
AH LA MIERD.. QUE ESTA HERMOSA LA GUACHA!!!! Eek mf dribble mf_lust
♏㋡ℕ㋡
♏㋡ℕ㋡
Cantidad de envíos : 6017
Mensaje por Green Hornet Lun Ene 10 2011, 15:50
Que hermosura,por Diossssssssssssssssssssssssssss ...!!!!!...
Green Hornet
Green Hornet
Socio Fundador
Cantidad de envíos : 6514
Mensaje por Shor Lun Ene 10 2011, 16:07
UNA COSA DE LOCOS!! HOY VOY A TENER SUEÑOS HUMEDOS CON ESTA MOTO JAJAJA
Mensaje por juancho_mdq Lun Ene 10 2011, 16:31
Shor escribió:UNA COSA DE LOCOS!! HOY VOY A TENER SUEÑOS HUMEDOS CON ESTA MOTO JAJAJA
shock 1
Mensaje por Shor Lun Ene 10 2011, 16:34
Juancho queda feo decir tan abiertamente q le haria el amor a esta moto ajajaja es heeeerrrrrrrrrrrrrrrrrrrmosa!
Mensaje por Invitado Lun Ene 10 2011, 17:20
Yikes Bounce worthy worthy y mucha muchaaaaaa
mf dribble mf dribble mf dribble mf dribble mf dribble mf dribble mf dribble mf dribble mf dribble mf dribble mf dribble mf dribble mf dribble mf dribble mf dribble mf dribble mf dribble mf dribble
Invitado
Invitado
Mensaje por sagrado Lun Ene 10 2011, 17:25
q fea q es....ojala tubiera 2 cry
sagrado
sagrado
Cantidad de envíos : 148
Mensaje por Kovach Lun Ene 10 2011, 18:25
Yo me sente en una... es bajita y chiquita. Me sorprendio porque en las fotos me parecia moto mas grande (fisicamente).
Kovach
Kovach
Cantidad de envíos : 259
Fecha de inscripción : 13/07/2009
Mensaje por Matutillo Lun Ene 10 2011, 18:29
Que buena que está, linda por donde la mires y el color... un bellezza mf_lust
Matutillo
Matutillo
Cantidad de envíos : 263
Mensaje por emid85 Lun Ene 10 2011, 20:10
Mira que a mi me tira el Custom. Pero eso es una BELLEZA! increibe lo buena que esta!
Si la hubieran querido hacer mas linda no creo que les haya salido
emid85
emid85
Cantidad de envíos : 889
Mensaje por comtec Lun Ene 10 2011, 22:02
Muy linda, muy linda, aguante kawa!!!!!
comtec
comtec
Cantidad de envíos : 6739
Mensaje por Kovain Lun Ene 10 2011, 22:26
tears
Kovain
Kovain
Cantidad de envíos : 4921
