KTM Avatar 125 cc
KTM Avatar 125 cc
Impresionantes las prestaciones y equipamiento de esta 125.
No creo que la lleguemos a ver por estos lados, pero posteo algo de info...
Habrá tenido algo que ver Bajaj en esta chiquitita?.
ENGINE
Engine type 1-cylinder, 4-stroke
Displacement 124.7 cc
Bore x stroke 58/47.2
Performance (homologated ) 11.3kW @10,500 rpm
Max. torque 12 Nm @ 8,000 rpm
Compression ratio DOHC
Starter /Battery Electric starter
Transmission 6 gears
Fuel Mixture Generation Electronic fuel injection
Control 4 V / DOHC
Lubrication Preassure lubrication
Final drive 14:45
Cooling Liquid cooled
Clutch Multi-disc wet clutch, hydraulically operated
Engine Management Bosch
CHASSIS
Frame Chromium-Molybdenum trellis frame
Subframe Steel
Handlebar Steel tapered DM 26/22 mm
Front suspension WP USD Ø 43 mm
Rear suspension WP monoshock
Suspension travel front/rear 160/160 mm
Front brake Disc brake Ø 280 mm
Rear brake Disc brake Ø 230 mmr
Rims front/rear 3,00 / 17″ x 4,00 / 17″
Tyres front/rear 110/70 x 17“ x 150/60 x 17“
Silencer Steel (KAT)
Stering head angle 65°
Trail 100 mm
Wheel base 1,350 +/-15 mm
Ground clearance 185 mm
Seat height 810 mm
Tank capacity 11 liters (ROZ 91)
Weight (ready to race) 128 kg
ENGINE
Control 4 V / DOHC
Final drive 14:45
CHASSIS
Subframe Steel
Trail 100 mm
Seat height 810 mm
Re: KTM Avatar 125 cc
El tema ya se esta tratando aquí: http://clubpulsarargentina.superforo.net/hablemos-de-otras-motos-f26/ktm-125-stunt-t917.htm
Daniel1973
Daniel1973
daniel1973- Cantidad de envíos : 1309
